I have an assembly with a sub assembly in it. My design table
is all set up, everything is just as I want it except...
I cannot find the header for setting whether a subassembly is Rigid or Flexible(found in the properties of the subassembly). Is this something that can be set in a DT?
I tried changing one and opening the DT to see if it would pop up in the list of things to add, but it doesn't show up there.
Any and all help is appreciated.
Misty
Misty
Not possible to control sub-assembly flexibility in a design table. Your option is to set up the sub-assembly with a 'Flexible' configurationa and the locked configuration/s you need. Then, in the main assembly, always have it set to flexible and control the configs with the design table.
Don
