Hi all,
Hope all is fine!!!!
Could anyone please help me out on my below requirement?
I am not very much familiar about the loft cut feature and because of which I am stuck up in one of the step and not able to proceed further.
I have a hollow cylinder. To that cylinder, I need a slot cut wherein it has to display an Oblong / Obround slot when viewed from the top (See attached image).
(THIS OBROUND SLOT HAS TO BE DONE USING "LOFT CUT" FEATURE ONLY)
Thanks a lot in advance for the time and for the solution.
Raju R
What is the reason that it can only be created with LOFT command?
because that looks like normal slot on plan view.
if u really have to do it by loft, just create 2 identical sketches on 2plnes and do loft cut
