Roger Morton
Top Level STL File Export
Discussion created by Roger Morton on Apr 22, 2009
I am trying to use Solidworks with SolidCam and for ease of assembly of a model in SolidCam need to output a preconfigued assembly using a specific co-ordinate system. As far as I can tell I only have 2 options (1) Get an STL file for EVERY part used in the entire assembly or (2) a singl STL file for the whole assembly. Ideally I want a single STL file for each sub-assembly used in the assembly. If I just export an STL for each sub-assembly then I loose the global co-ordinate system and have to spend hours figuring out the offsets and transformations in SolidCam.
I am sure there is a better way...anyone know how?
Roger Morton
