Hello everybody,
I'm having troubles when using 'sketch driven component pattern'.
I need to pattern an insert to be fitted in the three hex holes on a sheet-metal part.
I don't like using 'sketch driven component pattern' in assemblies. I rather use 'Pattern driven component pattern', but in this case the three holes have not been created with a pattern and I cannot change it, as it's a common part created and used by others, too.
So, I created the sketch in the assembly
then I mated the first insert
then I patterned it
Everything looks fine, but it's not!!
I should have the original part and two additional components in the pattern but, looking at the tree, I get the original part and three additional components in the pattern, that counts four in total.
What's wrong?
I solved it with a workaround by suppressing the first instance in the pattern, but I think SW shoundn't work like that.
I'm on SW2018 SP5
Do you get the same?
