In an existing hole table, I want to change the tag numbers to match the hole table tags of the mating part.
I have manually moved each hole row in the table to the order that I want, but when I ask to re-number the tags, it just moves them back to where the were.
Hole Table numbers are based off of their physical location in the part, it labels starting in the bottom left of the view. There is no real way to specify a hole as any given value.
There are a number of (seemingly very similar) SPRs related to re-ordering Hole Tables so you should probably vote for some/all of these for a chance of seeing this in a future release.
SPR 473437: Drawings, Tables -Hole Table: Enhancement: Ability to control hole table tag scheme. i.e. Order of hole in the Hole table. (allow for polar/circular hole table scheme; ordinate dimension, coordinate)
SPR 545241: Provide the ability to edit the tags in the drawing view for a hole table
SPR 598051: Provide ability to rename the tags in hole table.
SPR 608126: Ability to sort hole table by type of hole, including size. ( order arrange renumber )
SPR 837432: Ability to re-order hole table items by drag / drop
SPR 893643: Ability to block renumbering of all or a series of holes
SPR 984838: Ability to define order of holes within a hole table by direct selection order of holes
How do I vote on an SPR in the Knowledge Base?
