KWKevin Wilson09/10/2019
Hey all,
I'm very new to the macro world, but I'm trying to learn and was looking for a little help.  I've cobbled together a macro (mostly stuff posted here by that can rename Weldment cutlist items using "Filename-ConfiurationName-Counter".  Everything works well except the Configuration part.  The macro renames cutlist items in all configurations using whichever configuration is currently selected.  What I would like is a macro that runs on all configurations, but renames using each cutlist's specific configuration.  Here's my code...can you help, please?
Option Explicit
Dim SwApp As SldWorks.SldWorks
Dim swConfig As SldWorks.ModelDoc2
Dim sModelName As String
Dim sConfigName As String
Dim Part As SldWorks.ModelDoc2
Dim swFeat As SldWorks.Feature
Dim boolstatus As Long
Dim foldercount As Integer
Dim prefixName As String
Sub Main()
'prefixName = InputBox("Enter a prefix for the cut-list folder names")
foldercount = 0
Set SwApp = CreateObject("SldWorks.Application")
Set Part = SwApp.ActiveDoc
Set swModel = SwApp.ActiveDoc
Set swConfig = SwApp.ActiveDoc
'File name with extension
sModelName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
Debug.Print sModelName
'File name without extension
sModelName = Left(sModelName, InStrRev(sModelName, ".") - 1)
'Read Configuration name and write it to variable string
sConfigName = swModel.GetActiveConfiguration.Name
Debug.Print sConfigName
'Label1.Text = String1.Substring(0, 5) & "-" & String1.Substring(5)
prefixName = sModelName & "-" & sConfigName & "-"
If Part Is Nothing Then
MsgBox ("A part must be opened")
Exit Sub
If Part.GetType <> 1 Then
Exit Sub
Set swFeat = Part.FirstFeature
TraverseFeatures swFeat, True
Part.ClearSelection2 (True)
Sub TraverseFeatures(ByVal thisFeat As Feature, ByVal isTopLevel As Boolean)
Dim curFeat As SldWorks.Feature
Set curFeat = thisFeat
While Not curFeat Is Nothing
If Not isTopLevel Then DoTheWork curFeat
Dim subfeat As SldWorks.Feature
Set subfeat = curFeat.GetFirstSubFeature
While Not subfeat Is Nothing
TraverseFeatures subfeat, False
Dim nextSubFeat As SldWorks.Feature
Set nextSubFeat = subfeat.GetNextSubFeature
Set subfeat = nextSubFeat
Set nextSubFeat = Nothing
Wend
Set subfeat = Nothing
Dim nextFeat As SldWorks.Feature
If isTopLevel Then
Set nextFeat = curFeat.GetNextFeature
Else
Set nextFeat = Nothing
Set curFeat = nextFeat
Wend
Sub DoTheWork(ByVal thisFeat As Feature)
If thisFeat.GetTypeName = "CutListFolder" Then
If thisFeat.GetSpecificFeature2.GetBodyCount = 0 Then Exit Sub
foldercount = foldercount + 1
boolstatus = Part.Extension.SelectByID2(thisFeat.Name, "SUBWELDFOLDER", 0, 0, 0, False, 0, Nothing, 0)
Part.SelectionManager.GetSelectedObject5(1).Name = prefixName & IIf(foldercount < 10, "00" + CStr(foldercount), IIf(foldercount < 100, "0" + CStr(foldercount), CStr(foldercount)))
