I can't get my part to appear correct in my assembly...
Question asked by Dan Pihlaja on Oct 8, 2019
Latest reply on Oct 8, 2019 by Dan Pihlaja
OK, here is a simple example:
Part as it looks when it is opened separately:
Now, the same part added to my assembly:
Obviously, the part at the part level is white, while at the assembly level it is grey.
I have checked the overrides at the assembly level and removed them all:
I have looked at the scenes and the lighting and there is no difference between the part and the assembly as far as I can tell.  All the lighting is the same color and intensity between the part and the assembly level.
What else can I check?  What am I missing?
Edit:
SW 2018 SP5
And here is the same part added to a new assembly using my template and they look different:
So the problem may be in my template....but how do I check this?
I will dumb this part down a bit and attach it to see if anyone else gets this.
Edit 2:
I have attached an assembly as an example.
