I am working with an assembly that has a gear mate in it which works perfectly. When I put this assembly into another assembly, thus turning it into a sub-assembly, the gear mate no longer works. This means that one of the gears is locked, and the other one moves freely.
I have defined the sub-assembly to be flexible so I am pretty sure this isn't the issue. Any one has any ideas as to why this might be happening?
I am using SW 2009 SP3. This also happened with SP0.
Thanks!
I have tried to replicate your gear mate problem in sub assemblies and have not been able to. I too am using 2009 SP3.0. I tested my worm gear mate and then dropped it into an assembly and set flexible and it rotates as it should. I went one step further and dropped this assembly into another assembly, making the gear mate assembly two deep and it still works. Try to post some screen shots of your assembly and mates so we can help diagnose. See my video below.
Flexible gear mates
