Hi all,
I am trying to save a file in Solidworks as SAT to make it compatible with other software.
My only problem is: when I save is as SAT, the file turns into a file of around 20mb. This is too much looking at the fact that I have to combine multiple SAT files later on in the other software. While the original file is around 6 mb or less.
Do you have any tips for me?
A tried to save it directly as SAT with he "save as" option.
I also tried to save it by clicking on: Export to AEC en save it as SAT through this way. With high detailing the file is just as big as saving it directly as SAT with the "save as"-button. So this makes no difference. I also tried it with less detailing, but after that the file wasn't imported correctly in the other software (parts were missing).
I saved an assembly as a part because I wanted one part with all the solids in it. Hard to explain, but could that be the problem? Or is there a way to choose the size of the file van using the "save as"-button.
Thank you!
Greetings
Did you try saving the *.sldasm directly as a *.sat?
If you add up the sizes of each instance of each *.sldprt file what is the total size?
