Complex draft angle - is there an easy way to do this?
Question asked by Steven Mills on Oct 3, 2019
Latest reply on Oct 3, 2019 by Ravi Teja
I need to add a slope to a the highlighted face of this part. The draft angle tool doesn't seem to do it well, even if I split the face into different sections. Easiest way I found is to it make a sketch on the inside of the part that is a little below the edge, then use that to make a surface to the outside edge. Then use split to cut the part into different bodies. Then delete the extra surface and solid bodies.
