So, I was looking at trying to modify the custom crosshatching for a specific material (and others.....but lets start with one):
And I found this link:
SOLIDWORKS Custom Cross Hatching
Which seems to imply that the crosshatch pattern that is shown (ANSI32 (Steel)) takes its definition from this file:
This file is located on my hard drive. According to the link, editing that file for the crosshatch pattern that I want to change will change how the crosshatch looks.
However, this means that (I think), if I change my file, then when someone else opens a drawing that I have created, they will NOT see the custom crosshatch that I created unless I copy that sldwks.ptn file to the same folder on their computer.
So...…..If I am working in a multi-user environment, how do I make it so that the custom crosshatch pattern is available to all without copying files to their computer? The "File Locations" area of the Options inside Solidworks does not have a location for custom cross hatch...
one caveat: Since I do NOT have administrative rights (thank you IT!! ) to my computer, I cannot change this file. I can make a copy of it and change the copy, but I cannot rename or overwrite the file to be able to even test out whether or not the above link even works.
