I would like to have a script to add vault view on client machines. Hoping to run this batch file after install of the Admin Image. We'll see, but first I need to create the .cvs file per the solidworks help page:
2019 SOLIDWORKS PDM Help - Scripting Vault View Setup
It says this:
To distribute the vault view using login scripts, launch the View Setup wizard with triggers to automate view installations.
I run this and get error, the pdm admin log shows this:
Description:
Failed to find any archive server for vault with ID '{vault ID GUID from admin tool Vault->RMB->Properties}'.
Date: 2019-10-01 11:53:34
Module: ViewSetup.exe
Function: CViewSetup::mvAddGUIDVaults
Error code: E_FAIL
Error code general description:
An unspecified error occurred.
I'm thinking it cannot find the server, but where to I tell it what server to use? When I manually add a server using the View Setup GUI I add server name. Come to think of it that box is always empty, is there a way to tell the clients a default archive server to go to? Or add archive server name to the command? Or am I completely up the wrong tree here?
This page leads me to believe maybe the server is not broadcasting on 3030..
2019 SOLIDWORKS PDM Help - Distributing a Vault View in a WAN Environment
This page tells me how to enable/dissable the broadcast and how to set default server to use:
2019 SOLIDWORKS PDM Help - Configuring the Archive Server
but after I add the "Classic Administrative Templates (ADM)" to Administrative Templates I do not have any of those settings mentioned. Just "Archive Server" with the settings
- Disable socket writethrough - not configured
- Archive Compression - not configured
Thanks.
I have always just used the /a option to create the cvs file. The only problem is that you have to have a computer that does not have the local view installed on it, or remove it before you create the cvs file.
The CVS file is just a text file with the following content:
[{AttachSettings}]
Location=C:\
ViewType=SharedView
[VaultName]
VaultID=
A8E07E93-F594-42c9-A01B-F613DBA53CB5
DbName=ServerName.Domain.com
ServerLoc=Servername.Domain.com
ServerPort=3030
I highlighted the stuff you would change in purple.
*** I also notice that you used the {} brackets on your script line while the CVS file does not have them. Maybe try removing them from the script line.
