BSBindhu Supraja27/09/2019
Your serial number does not entitle you to SOLIDWORKS 2016. If your license is new, you may want to try again later. Otherwise contact your reseller to verify that the number is correct. You will still be able to choose the products you want to install, but you will not be able to download any installation files. If you continue without downloading enabled, you will need to provide a complete set of download source files or a DVD from which to install.v
