Ive got a macro that changes the width of my feature tree and it was working right up until I installed SW2018 this week. it works in 2018 but not 2017, (Ive had to switch back to work on a project that's not ready to upgrade to 2018) this is the error I get. Is their anything I can do to make it work in both?
and here is my code. Ive attached my macro as well.
Dim swApp As Object
' Preconditions: Model document is open.
' Postconditions: Width of FeatureManager design tree is controlled by myWidth (default 400).
Option Explicit
Dim nWidth As Long
Dim NewWidth As Long
Dim nRetVal As Long
Dim myWidth As Integer
Set swModel = swApp.ActiveDoc
myWidth = 735
nWidth = swModel.GetFeatureManagerWidth
nRetVal = swModel.SetFeatureManagerWidth(nWidth / nWidth * myWidth)
NewWidth = nWidth / nWidth * myWidth
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Old width = " & nWidth & " pixels"
Debug.Print " New width = " & NewWidth & " pixels"
The libraries could be messing up, so make sure they are set for the version you want to use
Also I've refined the codes, check below.
