We updated Local Vault view, and now when completing vault view set up, I cannot link the existing folder in Local C Drive.
Does anyone know how to connect old vault view after reinstalling local vault view? I need to retain old local view because of files that are checked out.
You may have a bad or corrupt client or vault view. I'll have to make some assumptions here. The biggest issue is that you may have a different vaul view ID and your machine may be recognized as a different client. even if its the same user on the same machine. With these steps, it doesn't matter. however, you will need to restore the files (see #7).
Transform the vault view into a regular yellow windows folder:
the vault view is now a regular windows folder. if not, you have IT-related permissions that are not allowing this to happen. stop and call your IT and your VAR together.
5. now that your vault view is a regular yellow windows folder, rename it with -old sufix. if you can't rename it, you have IT-related permissions that are not allowing this to happen. stop and call your IT and your VAR together.
6. perform a clean uninstall of your PDM Client (note that you may need to attach access - be prepared to provide the windows password to the archive server) if you do not know what I'm speaking about, stop and call your IT and your VAR together.
SOLIDWORKS PDM – Cleanly Uninstall and Reinstall a PDM Client | GoEngineer
7. Restore previously check out files by undoing checkout and overwriting checked out files with the ones in your Vault-old yellow folder. these steps are restoring form a crashed computer but the steps are the same, just see the files to restore as the ones contained in our renamed yellow folder.
https://files.goengineer.com/docs/support/Crashed%20Computer%20Recovery.pdf
you may want to think of what files are necessary for restore and which ones you just want to undo checkout (i.e. don't waste time on sandboxed files you were only using for testing but never checked in)
Regards,
Francisco | CSWS-DMA
GoEngineer.
