I'm looking for a macro that will grab all dimension and use Auto arrange.
Ive found the below two snip its of code, is it as simple as take the line from one and replace the center dimension line?
from Insert Auto Arrange Dimensions Macro? I've got this line
status = swModelDocExt.AlignDimensions(swAlignDimensionType_e.swAlignDimensionType_AutoArrange, 0.001)
and the select all dims from this post Select and center all dimensions on a drawing
Dim swDoc As SldWorks.ModelDoc2
Dim swDwg As SldWorks.DrawingDoc
Dim swDispDim As SldWorks.DisplayDimension
Dim swView As SldWorks.View
Set swDoc = swApp.ActiveDoc
Set swDwg = swDoc
Set swView = swDwg.GetFirstView
While Not swView Is Nothing
Set swDispDim = swView.GetFirstDisplayDimension5
While Not swDispDim Is Nothing
swDispDim.CenterText = True
insert my line here? status = swModelDocExt.AlignDimensions(swAlignDimensionType_e.swAlignDimensionType_AutoArrange, 0.001)
Set swDispDim = swDispDim.GetNext5
Wend
Set swView = swView.GetNextView
Wend
Thanks for your time!
Hello, try this:
