Can anyone help me with this problem I have. I attached the file and inserted a picture below to help explain. I have no idea why it is doing this and would like to fix the problem if at all possible. All I have been trying to do is extrude a flat piece to the body, but no matter which way I do it, I always have this problem. I will try to answer any questions possible if I can.
Hey Patrick,
Are you having issues with Boss-Extrude45? If you run a check on the model (Tools -> Evaluate -> Check) you will find 6 inconsistent faces that should be repaired. To avoid these inconsistencies, you may want to turn on the option 'Verification on rebuild (enable advanced body checking)' in the Performance section of your System Options while creating these features. You may need to back track to resolve issues with earlier features that are now preventing this one from working properly.
~Ben
