I use keyboard supr, and Right-click and selecting from the tree. And if press escape I can continue moving and opening parts, buts stops without deleting the parts
May be the solution of Deepak Gupta, because I had a problem with the registers, I reinstall and the problem do not solve until I delete the registers of that version of solidworks in HKEY_CURRENT_USER.
Check if your keyboard shortcut delete is set properly
Many thanks
