So im trying to turn that wireframe into a 3D surface,
I can't use revolution since the bundary isn't symetrical
I found this video where "boundary surface" is used to create a surface from 2 connected open spline, but mine are looped so i can't manage to make this work
I tried to split the splin so they will not curved into itself when lofted, the plan was to do as shown in the video for the 4 faces with tangent constraints on all edges, but even splitted in the sktech i can't manage to select a part of the spline in the loft command, it always select the whole sketch
Any idea on how to do this ?
Many thanks
Use the selection manager to refine your results or divide your sketches into axial quadrants and loft them individually.
For more help, I suggest sharing your model so others can provide a more detailed analysis
