Hi Everyone,
Normally, during Transform > Translate operation, the 'triad' (the movement arrows in 3 planes) is aligned to the center of the assembly. However, I have made an erroneous input and now the triad is some distance away from the assembly. The triad still moves the part, however I have to zoom out the screen to be able to view the assembly as well as the arrows.
- How to reset the triad so that it aligns once again to the center of the assembly?
- And if you could also tell what mistake I made to move the triad away from the assembly?
Thanks in advance for your help,
Regards
Apurva
Hello Apurva,
Either you change your geometry or you use the function shown in the screenshot below (sorry that this is in German language).
Hope this helps.
Regards,
Thomas
