Hi everyone,
I've looked for a solution to this issue on the forums and other sites but haven't found it. I'm running Solidworks 2013 and trying to execute simple macros in #TASK. The save to PDF macro from their online library is just an example of something that should work but I get this error. (see attached).
"Generic error. This indicates that #TASK failed to run a macro. Please make sure that you can run macros in SolidWorks"
I can export PDFs in SW manually and record/run macros.
Looking forward to a solution.
Thanks!
I just got this very same error. Using #Task as a workaround to SW not running our house Batch PDF macro. Uhg.
I submitted the issue with my VAR, I really don't want to save out 300 files manually.
