I'm trying to get a bunch of flat patterns on a single D-Sized drawing then save it out as a DXF. The issue I'm running into is when I try to separate my sketches/bend lines to separate layers (for etching), it won't allow me. I tried mapping as well but it seems like the "bend line" entity has been removed. I saw a post from 2014 and it use to work then. If anyone can help me I'd really appreciate it. Thanks!
I thought selecting Sketch lines would work since this toggles their display, but only the drawing's sketch lines went to BL.
As a workaround, do the part method and then use DraftSight (or equal) to copy and paste each DXF into the master drawing DXF.
Kevin
