Engineering Systems
swDocMgr.GetDocument  Error in Document Manager [swDmDocumentOpenErrorFutureVersion]
Discussion created by Engineering Systems on Sep 16, 2019
Latest reply on Sep 20, 2019 by Artem Taturevych
Hi Guys,
In document manager api GetDocument, I'm getting the error with
nRetVal value as 6 --> i.e, swDmDocumentOpenErrorFutureVersion
I'm trying to access the document solidworks 2018 document manager License key. The .sldprt is created
solidworks 2018 as well. I even tried to access .sldprt file created in solidworks 2012. But it shows the same error.
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Drawing
Imports System.Configuration
Imports System.Collections.Generic
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports System
Imports System.Linq
Imports System.Text
Imports Microsoft.VisualBasic
Imports ENOAPILib
Imports IEFAPILib
Imports SOLIDWORKSPLUGINLib
Imports SwConst
Imports EnoviaSW2Lib
Imports SldWorks
Imports SwDocumentMgr
Imports SwDimXpert
Imports ConisioCADLib
Imports ConisioFileFormatsLib
Public Class Form1
    Private Sub TestCheckIn_Click(sender As System.Object, e As System.EventArgs) Handles TestCheckIn.Click
        On Error GoTo ErrHandler
        Const sLicenseKey As String = "my_License_Key"
        Const sDocFileName As String = "E:\OldVersionParts\Four Port.SLDPRT"
       Dim swClassFact As SwDMClassFactory
       Dim swDocMgr As SwDMApplication4
        Dim swDoc As SwDMDocument18
        Dim swCfgMgr As SwDMConfigurationMgr
        Dim nDocType As Long
        Dim nRetVal As Long
        ' Determine type of SOLIDWORKS file based on file extension
        If InStr(LCase(sDocFileName), "sldprt") > 0 Then
            nDocType = SwDmDocumentType.swDmDocumentPart
        ElseIf InStr(LCase(sDocFileName), "sldasm") > 0 Then
            nDocType = SwDmDocumentType.swDmDocumentAssembly
        ElseIf InStr(LCase(sDocFileName), "slddrw") > 0 Then
            nDocType = SwDmDocumentType.swDmDocumentDrawing
        Else
            'Probably not a SOLIDWORKS file
            nDocType = SwDmDocumentType.swDmDocumentUnknown
            'so cannot open
            Exit Sub
        End If
        swClassFact = CreateObject("SwDocumentMgr.SwDMClassFactory")
        swDocMgr = swClassFact.GetApplication(sLicenseKey)
        swDoc = swDocMgr.GetDocument(sDocFileName, nDocType, False, nRetVal ' The nRetVal is 6 and swDoc is Nothing after executing this line
        swCfgMgr = swDoc.ConfigurationManager ' Error as swDoc is Nothing
ErrHandler:
        Dim ErrorMsg As String
        ErrorMsg = Err.Description()
        MessageBox.Show(" Error Number is : " + Err.Number.ToString + " : ErrMsg : " + ErrorMsg + vbLf + )
    End Sub
End Class
Artem TaturevychSolidWorks API SupportJason CapriottiDefault Default
