Why simulation results interfere?
Question asked by Naga Ranjithkumar Addagalla on Sep 11, 2019
Latest reply on Sep 11, 2019 by Shawn Mahaney
Hi all,
I did an analysis but I am in a little confusion whether my readings are correct or not due to following reason.
1. In one case, I added contact set "No Penetration" and run the analysis - I got one set of results for key and key way
2. In second case, I added contact set "No Pentration" and added displacement "0" (Radially and axially for key and key way relatively) then run the analysis - For the same case.
I found huge difference in readings.  Which case should I prefer?  When we run the analysis, should we consider applying fixture -> use reference geometry -> key surface fixed w.r.t keyway surface or not? - **After applying contact sets**
Please share your idea.
Naga Ranjithkumar A
