I'm trying to add some PEM pins to this panel using pattern driven component pattern but, only two of the pins are hitting the holes.
As you can see, the pins are in the right pattern but, it is offset from the part. There is also an additional position there that doesn't line up with the pattern.
I assumed I must have somehow accidentally created a pattern that doesn't line up with the part at some point but, I'm not sure how to investigate that possibility. I have examined everything in the feature tree and can't see a reason why this is happening. Any ideas?
Thank you in advance for your time.
Click on the "Select Seed Position" button, then choose the location that has the component you're trying to pattern. (I know the software should be smart enough to figure that out, but such is not the case.)
