I am making an exploded view of a product that has a lot of sets of mirrored items on either side. Is there a way to mirror the exploded view of each side so that each one is the same distance away in the exploded configuration? (Like where I could drag the right one further away from the center and the left one would also move away from center in the opposite direction) I want it to be symmetric but manually making both sides equal is very tedious and not precise. Please see the example below. Thanks.
Sure there is a way. Although it really isn't a mirror, per se.
You can use the radial explode option and select both components, and it will pull both sides away at the same time. I believe that it will pull them equally away the centerline between them.
