Is there a way to save the default line thickness to be printed to a drawing template?
Question asked by Erica Stringer on Sep 6, 2019
When I go to print a drawing I can select the "Line Thickness" option and set my thicknesses then hit print and everything works the way it should. I want to know is there a way to make this default so that I don't have to select that button every time I print? I went to print, chose my line thickness, closed the print box, saved as template, but that didn't work. I still have to select the box every time I print. We recently started using the PDM and it auto creates a PDF when we approve a drawing. Because it doesn't keep the settings the PDF does not show line thickness. I can open the drawing, select the line thickness, print to PDF and it works fine.
