Hello:
I am trying to look at a BOM in PDM and obtain the BOM level for assemblies. I am hoping to just look it up and have the information returned, however I am suspecting something is dependent on the whole BOM and it needs everything and cannot just calculate a selected item based on a relative path. I also feel the SolidWorks documentation for this is lacking!
My code looks like this:
Private Function GetAssyLevel(ByVal Assy As String) As Integer
Dim afile As IEdmFile7 = VAULT.GetFileFromPath(System.IO.Path.GetFullPath(SearchFileInVault(Assy)))
' Get a BOM view with the specified layout
BOMMGR = VAULT.CreateUtility(EdmUtility.EdmUtil_BomMgr)
Dim ppoRetLayouts() As EdmBomLayout = Nothing
Dim ppoRetLayout As EdmBomLayout
BOMMGR.GetBomLayouts(ppoRetLayouts)
Dim arrSize As Integer = ppoRetLayouts.Length
ppoRetLayout = ppoRetLayouts(0)
If ppoRetLayout.mbsLayoutName = "BOM" Then
BOMVIEW = afile.GetComputedBOM(ppoRetLayout.mbsLayoutName, 0, "@", EdmBomFlag.EdmBf_AsBuilt + EdmBomFlag.EdmBf_ShowSelected)
' Display BOM view row and column information
Dim ppoRows() As Object = Nothing
Dim ppoRow As IEdmBomCell
BOMVIEW.GetRows(ppoRows)
ppoRow = ppoRows(0)
Return ppoRow.GetTreeLevel
End Function
It returns a Tree Level of 0 for every assembly.
Thank you!
GetTreeLevel is relative to the assembly you opened. So it would be 0 because you're calling it on the first row on the selected BOM.
