Hello All.
I keep getting corrupted symbols and I'm not sure why. The symbol will be created, saved, and used in a metric sheet.
The symbols will work for some time then seemingly randomly break and I have no idea why. Sometimes the same symbol can be used on a different sheet fine, but if I try to use that symbol in a, now broken, sheet the symbol is messed up for that sheet.
I'll then make a new sheet to re-draw this and sometimes even on a new sheet the corrupted symbol will follow it. At times when I look into the symbol it's perfectly fine and other times the circuits are 10-15mm away from where they should be, attributes have gone their own way, etc.
Scenario 1 - Symbol is corrupted:
I can rebuild the symbol and continue to use it.
Scenario 2 - Drawing is corrupted:
I can rebuild the symbol, but the sheet is broken. I need to redraw everything on a new clean sheet. Wires will disappear when I draw them or the symbol refuses to cooperate and update on the sheet.
Scenario 3 - Symbol is corrupted:
I can rebuild the symbol and on a new sheet, the symbol is still corrupted. I need to delete the symbol and re-draw the symbol and everything that was in the sheet.
Any ideas what could cause this?
