In exported SVG images with BOMs, is there any way to display more than one highlight color among actors? Generally I want to keep the default green highlight. But I'd also like to be able to change a few parts so they highlight in a different color when the callout or BOM line is selected. This would signal the user that an embedded hyperlink exists if he/she clicks these specific parts.
I did try to create hotspots from these parts, defining them as orange, but "Generate Hotspots from BOM IDs" seems to override my created hotspots. Everything comes out green, and my orange coloring and hotspot tool tips are not visible. I would appreciate any suggestions or tips. Thank you.
your wish is a little bit tricky
if you want to use a BOM ist not possible to use both Manual hotspot an automatic BOM Hotspot.
In this case you have to look for some who know to modify the XML code of the SVG File.
Otherwise work with some piktograms to provide Links.
