I am trying to create a series of 1" Hem Bends with a spacing of 1" along the same edge.
I tried creating one 1" Hem Bend and attempting to linear pattern it along the same edge, however it said "Unable to pattern selected feature Hembend 1".
I also tried editing the sketch of the Hem Bend feature and adding spaced out lines but it says it can only apply the Hem Bend on one line segment.
What I have had to do is create several different Hem Bends to achieve this. It's a solution, but it's a messy one.
I'm able to do it in SW2019 version. So which version you are using?
As workaround, you can create the hem along with complete edge. Then do a cut extrude and pattern that feature to get the desired result.
