is there another way to collapse an assembly? the only way I know to do it is to right click the explode configuration inside configurations tab and select collapse.
my problem is that a lot of times when I open an assembly model, the model is exploded so it takes multiple mouse clicks to navigate to the configuration menu, expand the appropriate configuration (which can take time as well if there are multiple configurations) and then right click to collapse.
a sort of short cut is to just click the explode assembly icon on my toolbar and then cancel right out but that seems backwards.
If you open an assembly and it is already in the exploded state, you can right click in the graphics window and select "collapse" (two mouse clicks) from the RMB pop up window.
