I added logo to each of views in the composer. However, when each views changes the logo also rotates along with the model, which is annoying. How do i keep my logo immobile whilst moving from one view to another?
Thanks.
Thanks.
In Composer there are two different Kind of Panels 3D and 2D.
If you wnat to use Panels like 3D planes which are able to rotate use the left "IMAGE" this is 3D
If you want to use Logos in front or in Background of the Viewport, use "Image 2D" This is only 2D, not able to rotate.
If you want to force it in the Background, change the Property General > Background > enable (ON) otherwise it will remain in the front of the viewport!
Solution 1: Put the logo in the background. For this you need to create a background image with the logo and activate it in Composer. The logo will be fixed over the complete animation.
Solution 2: Use After Effects for integrating pictures (my favorite).
Hope this helps.
Regards, Thomas
