Hello guys,
When i try to use the new enhanced graphics performance option in my assemblies the Hide comand (Tab button, or command menu) doesn´t work properly.
It only hides the part/parts if i rebuild the assembly or use the isolate command.
My graphic card is a Nvidia Quadro P2000 with the 411.63 driver version, which is recommended.
System is W10 64, i79700k, a lot of RAM 2666MHz, etc....
This happends in SW20019 SP3 and SP4.
I tried with different driver versions (new ones) but nothing changes with this issue. For the rest, graphic card works like a charm.
Anyone else with this problem?
Greetings,
Ruben
Contact your VAR/reseller and hope they fix it in the future.
