Hi All,
Is there a way to rectify this.
1. In description for Item 1, there a too much space/gap between the the text Plate 10 and mm.
2. How to get the full flattened length of the sheet metal part in description. Currently 586 being shown is not corrected.
3. How to write the description of Sheet following with the thickness and mm as default (same as Plate description above)?
4. Sometimes, plates of 10mm or 15mm are bent. How do we get the flattened length of the plates in description?
I have used the settings as shown in the second image below. I am using the latest SW 2019 SP 3.0.
Regards,
LS
