Sometimes when I change the transparency of a part it is not
see-through even though the icon claims it is suppose to be.
Other times a part remains transparent even when I have shifted back and I have to give it a nudge with rebuild.
SW09
SW09
But once the part is Glass the other annoying problem happens.........you cant select any of the faces, surfaces, edges of the part with out using the select other option. Or by rotating the assembly so the part has nothing behind it.
And then when using select other you have no idea what your selecting so it becomes a game of hit and miss..........
And these problems have been happening for a very long time.
This also leads to the Drawing problem with Transparent parts........they show as a solid in the drawing with out any indication that they are a transparent part, so I have to hide the part and hand sketch lines to indicate a "glass" part is there.
