When you have a weldment with a bunch of sheet metal parts is there an easy way to get the flat pattern for each of those parts? Right now we make a configuration that suppresses and unsuppresses each flat pattern for each sheet metal part. That's a bit of a pain if you have a dozen sheet metal parts.
Just wanted to know if there was an easier way.
If you select the sheet metal body you want to flatten, either from the modeling space or from your cutlist folder, before you click flatten, then this will allow you to dictate which sheet metal body you are flattening.
