Solidworks Flow Simulation - Mesh Density
Question asked by Justin Sadler on Aug 24, 2019
Latest reply on Aug 25, 2019 by Justin Sadler
If the mesh generation is taking several hours and looks to be restarting as I check on it, is this a early sign that mesh or geometry of model should be re-examined?  Everything set to default mesh settings, no local mesh refinement yet.  Outlet at standard pressure with inlet at a volume flow rate.  If you have too large a mesh would this happen?  The only geometry issue I noticed was a tangent line contact in the check geometry results, but beside line item the solver stated resolved.  If the solver says resolved for issue, do I necessary have to fix it?
Computer
32 GB RAM
Intel Xeon 3 GHz
Model
A 6' x 6' x 2' box with an inlet and outlet.
Box contains 64 parts to be cooled in a x/y array pattern
