I can't seem to get get Ent PDM variables to map to the
Inventor iProperty "Stock Number". I've tried variations on the
dtproperties and no luck. Any ideas?
As far as I understand it, create the variable in EPDM using
dtproperties as the block name and then StockNumber as the
attribute name (notice there's no space in Stock Number). Make sure
you have the correct file extensions and that should set EPMD up.
This is directly out of the admin manual in the back of the book:
Variable name: Stock number
Inventor Prop name: Stock Number
Block name: DTProperties
Attribute name: StockNumber
I am trying to push data from the EPDM template card to the
Inventor dtproperty for new files so that it works with my
customer's inventor templates.
It is the Stock Number property that I cannot seem to push data to.
I can use my EPDM Template file card to push Part Number and other
data but just cannot seem to get that one to work.
Hope that helps.
