I am a relatively new user to SW , I know how to revolve a thin part, but do not know how to revolve a small (or any size) rod that has two 90 deg bends.
Would appreciate some guidance here.
Its not revolve.
Sweep or loft.
Tried those neither seem to work, I have a center line for it's center, solid line for the profile. Is that my problem?
The Centerline needs to be a sketch and the profile needs to start at one end of the path sketch..
Go to Help and follow the Tutorial.
Is this what you want?
Sweeps
use a weldment. draw your sketch and put some tubing or a pipe on it. that is the easy way.
Its not revolve.
Sweep or loft.
