Is there a way to include all bodies multi-body part' BOM?
Note: I get multi-body part from an insert part which includes all CusProp such as Material, Revision etc... how to link these cusprop to the BOM
Thank you, Henk
As I mentioned in the OP, I have a multi-body part from inserting external pat which includes CusProp such as Revision. Using Cut-List, I don't see the option Revision CusProp
I did checkmark that option but somehow the CusProp from the insert part is not showed in the cutlist
Hi Christian Chu ,
Material is a body-property.
Revision is a file-property.
When importing a part into a part, you have to choose File properties or Cut list properties.
If you select Cut list properties than the Revision-property of the imported part is ignored.
If you select File properties than they have to be synchronized, becaue after importing it is one file, and you get a warning message like:
After importing, the body-properties can ony be updated from within the file containing the imported part, not from the original part.
Hi Christian Chu ,
Maybe I have got some workaround for you.
Best way is to create a Cutlist instead of BOM, because I think Cutlist looks better.
I did both in the example.
You can assign a custom property for the Part (file-property) as well as the Body (Cutlist-property).
I assume you want Them synchronous, so I created a GV : PartRevsion in Equations.
Revsion (part-property) => GV (PartRevsion) => Revsion (cultlist-property), so they synchronize.
I have added "Revision" as and extra cutlist property for each cutlist item, before importing.
I imported Multibobody-Part2 into Multibody-Part1 and checkmarked CustomProperties and CutlistProperties.
See example file including drawing SW2018
The good thing is when the Revison (part-property) in the single file Multibody-part2 is updated, it also updates in BOM and Cutlist.
Hi Christian Chu ,
Yes you can;
