How do you model a bent tube in order to get a flat pattern of the tube. I am creating a roll cage and want the flat pattern and bend lines to show up in the drawing for easy fabrication. The tube is rounded.
Ok, so what is the correct way to model round tube in a roll cage so I can get how much tube I need to purchase, and easily show on drawings where the center of the bend should be?
Maybe a weldment?
Using Weldments and its features
Locating Structural Members in SOLIDWORKS Weldments
You can also get the total length of your tube this way as well as it is calculated for you.
https://hawkridgesys.com/blog/how-to-create-a-custom-weldment-cut-list-template-in-solidworks
SOLIDWORKS Weldments from Profiles to Cut Lists – Part 4 - Computer Aided Technology
Check out this thread for possible solutions: How to bend the open tube?Used for laser cutting, manual bending and final welding.
Steve Labonte This is exactly what I was looking for. I just do not understand how you kept the Flatten-<BaseBend#> in the Flat Pattern after you Fillet the entire bar. My Flatten-<BaseBend#> goes away in my Flat Pattern when I use the Fillet feature on the bar. This causes me to have no Flat Pattern.
"Sweep Flange"
...ok,.. forgot,.. thought we could.. ?
