Solidworks 2019 (or I) have an issue when doing the following:
- imported an IGES file
(gives multiple bodies in a single model (SLDPART) - as expected!)
- Aligned all bodies with SW co-ordinates using:
>> Body-Move/Copy to translate only*#
>> Body-Move/Copy to rotate*
*Note: Copy option not selected
This all works fine.
Fault:
However, whenever the PART file is re-opened, SW displays:
- bodies in correct position (after the Body-Move/Copy)
- bodies in original position also (!!?)
Rebuilding clears the display up (ie only the repositioned bodies are shown - as expected).
The Feature Manager Design Tree shows duplicate bodies - until rebuild occurs!
This issue is repeatable (i.e. with Open, Rebuild, Save).
Drawings
Drawings are also affected (until the Model is Opened and Rebuilt): original and moved bodies are displayed in each View! As real nuisance!
Simple Example - attached
Contains a single (imported) cylinder: has same issue.
Screen shots show:
1) as opened,
2) after rebuild.
Note the \Solid Bodies entries alter when rebuilt!
If the bodies are 'native' (ie. not imported), the problem does not seem to occur.
Bug?
This seems like a bug? Already reported?
SW installation issue?
(FYI: I cannot submit bug reports)
Avoidance? Fix?
Can this issue be avoided? I could not find any solution, or reference...
Is there a different/better way to import multi-body IGES files (originates from VectorWorks)?
Is it possible to 'convert' these imported bodies to 'native' SW bodies (as they don't exhibit the issue).
Any help appreciated!!
Thanks.
// Lee
p.s. this forum link shows usage of Move/Copy command to re-orientate bodies...
UPDATE:
More info:
Just tried the following on the single-body test file:
- Open the part file (duplicates show as above)
- HIDE just the imported, duplicate body (leaving the moved/copied body as visible).
- Rebuild: hides both bodies (and correctly shows one body in the Design Tree)
Then...
- UNHIDE the correct, remaining body, to show it.
- Save, Close.
- Re-open... issue STILL remains!
