Cone Development using Sheet Metal
Question asked by Davin Thorley on Aug 22, 2019
Latest reply on Aug 23, 2019 by David Matula
I have always used the lofted bends in Sheetmetal to create a cone. Recently I have had the need to add a flange/lip to the top of the cone. To do this I have had to use the Swept Flange method. Although this models correctly and is dimensionally correct, I am having problems with my flat pattern which I send to a laser cutter. There is a difference in the cut out dimension in the flat pattern when using lofted bends or the swept flange commands and I'm struggling to comprehend which is the correct/most accurate method to use.
Has anybody had a similar issue or can advise which method they use?
sheet metal cone
cone with flange
sheet metal flat pattern
