Gregg Essex
Add saved BOM sort to existing Macro
Discussion created by Gregg Essex on Aug 21, 2019
I am working with some legacy Macros in Solidworks 2016 in the company for which I work. I do not have much API skills, but was wondering if I could get some help altering an existing Macro. The macro we use takes all parts with a specific 'work' tag and the creates a BOM and isometric display on the first page, then on each page after, gives views of each part to be created. I have a BOM that has a specific sort within it that I want to use (which is referenced in the Macro), but every time the Macro is run, the BOM is in a basic sort (not the one that I have as the 'saved sort'). Is there a way to get the macro to 'apply' the saved sort from the default BOM?
MAX PARTS DRAWINGS
Dim swApp As Object
'----------MODIFIED TO SORT BY WORK
'-------------LFL 05.22.2018
'added all vendor bypass, eliminated Buyout gate, and changed sub to boot from drawing file with good templates
'-------------LFL 8.17.2017
'correctly differentiates between parts and assemblies
'-------------LFL 5.20.2017
'--------PART DRAWING AUTOMATION--------
Dim Ass As SldWorks.AssemblyDoc
Dim Comp() As Object
Dim strFileName As String
Dim FileTyp As Integer
Dim countNum As Integer
Dim CompDoc As ModelDoc2
Dim CompDocFile As String
Dim CompDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
Dim Part As Object
Dim boolstatus As Boolean
Dim PageNum As Integer
Dim PartNum As String
Dim PartLog() As String
Dim PartLogCount As Integer
Dim Z As Integer
Dim TestPartNum As String
Dim FailFlag As Boolean
Dim BoCheck As String
Dim BoLog() As String
Dim BoCount As Integer
Dim AssCount As Integer
Dim SkipCount As Integer
Dim ConfigLog() As String
Dim TestPartConfig As String
Dim ConfigInstance As String
Dim GoodComponents() As Object
Dim GoodComponentNames() As String
Dim GoodComp As SldWorks.Component2
Dim GoodCompCount As Integer
Dim orderedComponents() As Object
Dim orderedComponentNames() As String
Dim orderedComp As SldWorks.Component2
Dim orderedConfig As String
Dim OrderedFileName As String
Dim vConfig As String
Dim gateVar As String
Dim compVendor As String
Dim seedAss As Object
Dim pickedFile As String
'Const swFilterSting As String = "SW Files|*.sldprt; *.sldasm; *.slddrw|Parts|*.sldprt|Assemblies|*.sldasm|Drawings|*.slddrw|ALL FILES|*.*|"
Const swFilterSting As String = "Assemblies|*.sldasm"
Dim seedConfig As String
Dim drwDocName As String
Dim startTime As Double
Dim includeInitials As Integer
BoCount = 0
AssCount = 0
PartLogCount = 0
drwDocName = "default"
'defines the drawing from beginning
Set Part = swApp.ActiveDoc
drwDocName = Part.GetTitle
'MsgBox (drwDocName)
pickedFile = swApp.GetOpenFileName("Select Assembly for Part Automation...", Empty, swFilterString, Empty, Empty, Empty)
seedConfig = InputBox("SPECIFY THE SEED CONFIGURATION FOR AUTOMATED PART SET - CASE SENSITIVE", "SEED CONFIGURATION", "*")
'gateVar = "STEEL CNC"
gateVar = InputBox("SPECIFY WORK FOR AUTOMATED PART SET - CASE SENSITIVE" & vbNewLine & vbNewLine & "KEY TO BYPASS GATE AND PRODUCE ALL PARTS: 'ALL'")
includeInitials = MsgBox("The WORK Gate is: " & gateVar & vbNewLine & vbNewLine & "1.  Program Requires and open and empty excel spreadsheet" & vbNewLine & vbNewLine & "2.  Program requires Coburn, or a similar animal, to be pet" & vbNewLine & vbNewLine & "3.  Would you like feature initials to be included on drawing sheet tabs?", 4)
'-----msgbox yes no is style 4. Yes returns 6, No returns 7
'-----start procedure
startTime = Timer
'opens new file for seeding, "part" is still tied to drawing file.
Set Ass = swApp.OpenDoc6(pickedFile, 2, 0, "seedConfig", longstatus, longwarnings)
Comp = Ass.GetComponents(False)
SkipCount = 0
For i = 0 To UBound(Comp)
    Set swComp = Comp(i)
    Debug.Print "i= " & i
        '-------suppression check
        If (swComp.GetSuppression = 3) Or (swComp.GetSuppression = 2) And (swComp.IsEnvelope = False) Then
        Set CompDoc = swComp.GetModelDoc
        Set CompDocExt = CompDoc.Extension
        strFileName = swComp.GetPathName
        CompDocFile = CompDoc.GetPathName
        FileTyp = CompDoc.GetType
        PageNum = i + 2
        'Debug.Print stringFileName
        Debug.Print CompDocFile
            If FileTyp = swDocPART Then ' swDocPART = 1 (declared as integer)
            'MsgBox ("file is a PART" & vbNewLine & "File Name: " & strFileName & vbNewLine & "File Type Integer: " & FileTyp & vbNewLine & "Component Doc File Name: " & CompDocFile)
            PartNum = Right(strFileName, 13)
          PartNum = Left(PartNum, 6)
            Debug.Print PartNum
            BoCheck = Right(strFileName, 13)
            BoCheck = Left(BoCheck, 2)
            'BO check removed--------
                'If BoCheck = "BO" Then
                'MsgBox ("buyOut Part #: BO " & PartNum & vbNewLine & vbNewLine & "SKIPPED")
                'BoCount = BoCount + 1
                'Else
            '----remove with BO if above
                    '-----added for vendor gate
                    vConfig = swComp.ReferencedConfiguration
                    Debug.Print vConfig
                    CompDoc.ShowConfiguration2 (vConfig)
                    Set swCustProp = CompDocExt.CustomPropertyManager("")
                    bool = swCustProp.Get4("WORK", False, val, valout)
                  compVendor = val
                    Debug.Print compVendor
                    If compVendor = gateVar Or gateVar = "ALL" Then
                    '----- see end if below
                    FailFlag = False
                    ReDim Preserve PartLog(PartLogCount)
                    PartLog(PartLogCount) = PartNum
                    ReDim Preserve ConfigLog(PartLogCount)
                    ConfigLog(PartLogCount) = swComp.ReferencedConfiguration
                    ConfigInstance = ConfigLog(PartLogCount)
                        If PartLogCount = 0 Then
                        Else
                            For Z = 0 To PartLogCount - 1
                            TestPartNum = PartLog(Z)
                            TestPartConfig = ConfigLog(Z)
                                If PartNum = TestPartNum And ConfigInstance = TestPartConfig Then
                                FailFlag = True
                                'Debug.Print PartLog(PartLogCount)
                          Next
                    If FailFlag = False Then
                    'Debug.Print PartLogCount
                    'Debug.Print PartNum
                    'Debug.Print ConfigInstance
                    ReDim Preserve GoodComponents(PartLogCount)
                    Set GoodComponents(PartLogCount) = Comp(i)
                    'GoodComponents(PartLogCount, 2) = PartNum
                    'GoodComponents(PartLogCount, 3) = ConfigInstance
                    PartLogCount = PartLogCount + 1
                    Debug.Print UBound(GoodComponents)
                    '----added for vendor gate
                    '-----vendor gate
                '------removed to eliminate BO check
                'End If
                '--------bo check
        If FileTyp = swDocASSEMBLY Then ' swDocASSEMBLY = 2 (delcared as integer)
        'MsgBox ("file is an ASSEMBLY" & vbNewLine & "File Name: " & strFileName & vbNewLine & "File Type Integer: " & FileTyp)
        AssCount = AssCount + 1
    'added for suppression check
    Else
    SkipCount = SkipCount + 1
    '-------- end added for suppression check
Next
'MsgBox ("BO Parts In Set: " & vbNewLine & vbNewLine & "     " & BoCount & vbNewLine & vbNewLine & "Lightweight, Suppressed, and Envelope Components Skipped: " & vbNewLine & vbNewLine & "     " & SkipCount & vbNewLine & vbNewLine & "Subassemblies in Master: " & vbNewLine & vbNewLine & "     " & AssCount & vbNewLine & vbNewLine & "Components included in Part Set:  " & UBound(GoodComponents) + 1)
'--------------EXCEL-----------------
    Dim Row As Integer
    ' Attach to active Excel object
    Set xl = GetObject(, "Excel.Application")
    ' Get  active sheet in Excel
    Set xlsh = xl.ActiveSheet
    xlsh.Cells.Clear
For i = 0 To UBound(GoodComponents)
    Set GoodComp = GoodComponents(i)
    strFileName = GoodComp.GetPathName
    ReDim Preserve PartLog(i)
    PartLog(i) = PartNum
    ReDim Preserve ConfigLog(i)
    ConfigLog(i) = GoodComp.ReferencedConfiguration
    ConfigInstance = ConfigLog(i)
    Row = i + 1
     xlsh.range("A" & Row).Value = PartNum
     xlsh.range("B" & Row).Value = ConfigInstance
     xlsh.range("c" & Row).Value = i
    GoodComponentCount = GoodComponentCount + 1
Next
    'MsgBox ("break line - sorted")
 '---- need to expand range
 xlsh.range("A1:C244").Sort Key1:=xlsh.range("A1:A244"), Header:=xlYes, Key2:=xlsh.range("B1:B244"), Header:=xlYes
 Dim IndexOrder() As Integer
 Dim SortedOrder() As Integer
 Dim Sort As Integer
    ReDim Preserve IndexOrder(UBound(GoodComponents))
    ReDim Preserve orderedComponents(UBound(GoodComponents))
    ReDim Preserve SortedOrder(UBound(GoodComponents))
        IndexOrder(i) = xlsh.Cells(i + 1, 3)
        SortedOrder(i) = i
    Next
        Sort = SortedOrder(i)
        For j = 0 To UBound(GoodComponents)
            If Sort = IndexOrder(j) Then
            Set orderedComponents(j) = GoodComp
                Debug.Print IndexOrder(i)
                Debug.Print Sort
                Debug.Print orderedComponents(j).GetPathName
                Debug.Print " "
        Next
    Next
'MsgBox ("Ordered Components QTY: " & UBound(orderedComponents) + 1 & vbNewLine & "Good Components QTY: " & UBound(GoodComponents) + 1)
    'activate drawing again
swApp.ActivateDoc2 drwDocName, False, longstatus
    'place drawing on cover
    Dim myView As Object
    Set myView = Part.CreateDrawViewFromModelView3(pickedFile, "*Isometric", 0.098, 0.25, 0)
    'Set swActiveView = Part.ActiveDrawingView
    Dim swBOMTable As Object
    Set swBOMTable = myView.InsertBomTable2(False, 9.52500000000001E-03, 0.220547524180041, swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft, swBomType_e.swBomType_PartsOnly, seedConfig, "T:\Drafting Templates\SWX\TE SWX TEMPLATES 2018\BOM STANDARD 8.5 X 11 - 2018.sldbomtbt")
    For y = 0 To UBound(GoodComponents)
    Set orderedComp = orderedComponents(y)
      orderedConfig = orderedComp.ReferencedConfiguration
            OrderedFileName = orderedComp.GetPathName
            '--- use this part number selector for shorter page tabs
            'PartNum = Right(OrderedFileName, 10)
            'PartNum = Left(PartNum, 3)
            If includeInitials = 6 Then
                PartNum = Right(OrderedFileName, 13)
                Else
            Debug.Print orderedComp.GetPathName
            'Debug.Print OrderedFileName
                    '--Make Sheets
                    '-----use reference from beginning
                    'Set Part = swApp.ActiveDoc
                    '-----use ref from beg - end
                    boolstatus = Part.NewSheet3(PartNum & " - " & orderedConfig, 0, 12, 1, 2, False, "t:\drafting templates\swx\te swx templates 2018\DRAWINGS - 2018\ANSI A - SHEET FORMAT - PD - 2018.slddrt", 0.1, 0.1, "Default")
                    boolstatus = Part.SetupSheet5(PartNum & " - " & orderedConfig, 12, 12, 1, 32, False, "t:\drafting templates\swx\te swx templates 2018\DRAWINGS - 2018\ANSI A - SHEET FORMAT - PD - 2018.slddrt", 0.2159, 0.2794, "Default", False)
                    'Dim myView As Object
                    Set myView = Part.CreateDrawViewFromModelView3(OrderedFileName, "*Front", 0.06, 0.1, 0)
                    'longstatus = Part.AutoDimension(1, 2, -1, 2, 1)
                    Set myView = Part.CreateDrawViewFromModelView3(OrderedFileName, "*Right", 0.16, 0.1, 0)
                    Set myView = Part.CreateDrawViewFromModelView3(OrderedFileName, "*Top", 0.06, 0.2, 0)
                    Set myView = Part.CreateDrawViewFromModelView3(OrderedFileName, "*Isometric", 0.16, 0.2, 0)
                    boolstatus = Part.ChangeRefConfigurationOfFlatPatternView(OrderedFileName, orderedConfig)
                    'boolstatus = Part.ActivateView("Drawing View1")
    Next
boolstatus = Part.Extension.LoadDraftingStandard("T:\Drafting Templates\SWX\TE SWX TEMPLATES 2018\DRAFTING STANDARD TE 8.5X11 - 2018.sldstd")
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDrawingSheetsMatchCustomPropVals, 0, False)
MsgBox ("Lightweight, Suppressed, and Envelope Components Skipped: " & vbNewLine & vbNewLine & "     " & SkipCount & vbNewLine & vbNewLine & "Subassemblies in Master: " & vbNewLine & vbNewLine & "     " & AssCount & vbNewLine & vbNewLine & "Components included in Part Set:  " & vbNewLine & vbNewLine & "     " & UBound(GoodComponents) + 1 & vbNewLine & vbNewLine & "Procedure ran in:" & vbNewLine & vbNewLine & "     " & Timer - startTime & " seconds")
