i need the lines to be repeated not with a constant pace. if it was so i could use the pattern. is it possible to have more than one distance to direct the repetition manner? i need one line to be repeated in 20 mm and then 16 mm and then 20 mm and so forth...(look at the attachment) what can i do ? do you have any suggestion?
First draw the two lines with a distance of 20mm between them.
Select those two lines and make a pattern with a distance of more than 20mm between them.
accept it and now dimension the space between the lines and you can change the dimension to the required length (16 in your case)
You can change the dimensions or number of items to what you need. just double click them.
