Extract "Sketch" Entity Information
Question asked by Darren Smith on Aug 18, 2019
Latest reply on Aug 19, 2019 by Rob Edwards
Can anybody help?
I have the following macro that lists the sketch "entity types" in a sketch...
Sub Main()
    Dim swSketch As SldWorks.Sketch
    Dim swSketchMgr As SldWorks.SketchManager
    Dim vSketchTextSegments As Variant
    Dim vSketchTextSegment As Variant
    Dim swSketchText As SldWorks.SketchText
    Dim swSketchLine As SldWorks.SketchLine
    Dim vSketchSegments As Variant
    Dim vSketchSegment As Variant
    Dim swSketchSegment As SldWorks.SketchSegment
    Dim bValue As Boolean
    Set swModel = swApp.ActiveDoc
    Set swSketchMgr = swModel.SketchManager
    swModel.ClearSelection2 True
    bValue = swModel.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
    swSketchMgr.InsertSketch False
    Set swSketch = swModel.GetActiveSketch2
    vSketchTextSegments = swSketch.GetSketchTextSegments
    If (Not IsEmpty(vSketchTextSegments)) Then
        For Each vSketchTextSegment In vSketchTextSegments
            Set swSketchText = vSketchTextSegment
            MsgBox "Text = " & swSketchText.Text
        Next vSketchTextSegment
    vSketchSegments = swSketch.GetSketchSegments
    If (Not IsEmpty(vSketchSegments)) Then
        For Each vSketchSegment In vSketchSegments
            Set swSketchSegment = vSketchSegment
            Select Case swSketchSegment.GetType
                Case swSketchSegments_e.swSketchText
                    Set swSketchText = swSketchSegment
                    MsgBox "Sketch text = " & swSketchText.Text
                Case swSketchSegments_e.swSketchLine
                     Set swSketchLine = swSketchSegment
                     StartPointX = swSketchLine.IGetStartPoint * 1000
                     EndPointX = swSketchLine.IGetEndPoint * 1000
                     MsgBox StartPointX, 64, EndPointX
                Case swSketchSegments_e.swSketchARC
                    ' Set swSketchARC = swSketchSegment
            End Select
        Next vSketchSegment
    swSketchMgr.InsertSketch True
I need to be able to extract the following information.
Line
X/Y Start Point
X/Y End Point
Arc
X/Y Centre Point
Radius
X/Y Start Point
X/Y End Point
Can anybody update the macro, shown above so that I can extract the information that I need?
Many thanks in advance!!!
Darren
