I have a weldment cutlist table in a drawing that is tabulated. The part is configured such that one item's qty is called out in the table under column C. How can I change the qty cell of the weldment cutlist table to just type the letter C? I know I can edit the description and part number columns by double clicking in them and breaking the link, but this doesn't work for the QTY column.
I found simplest solution. In the weldment model, select the cutlist item properties that needs the qty variable. In the QUANTITY Property Name uncheck the linked box. Now the Value / Text Expression can be edited.
This edited value will now show in the weldment cutlist table in the drawing.
