Gilad Nave
Unable to select or use Sketch-Pattern from DesignTree after macros.
Discussion created by Gilad Nave on Aug 13, 2019
Latest reply on Aug 13, 2019 by Gilad Nave
I am running a macros code (please find attached) in which I am creating few sketch patterns and bodies. After the macros runs, I need to be able to "play" with the created bodies: delete some of them, combine some of them, and re-pattern on the sketch (which are just dots at selected XYZ coordinates). Ideally it would be part of the macros script. However, for now I would just like to know why I am not able to select or use the sketch-patterns from the design tree and how I can solve it.
Please find attached the TXT files to run this code.
I would also like do credit @Ivana Kolin for the help with this script.
(The script is a bit long but uses 3 functions that are the same except for calling different TXT files)
Option Explicit
Dim boolstatus As Boolean
Dim swModelDoc As SldWorks.ModelDoc2
Dim swPartDoc As SldWorks.PartDoc
Dim swSketchMgr As SldWorks.SketchManager
Const pathName As String = "G:\My Drive\CALCE\Matlab\BugCheking\bugCheck\"
Public Sub main()
Dim vSkLines As Variant
Dim myDisplayDim As SldWorks.DisplayDimension
Dim myFeature As SldWorks.Feature
Dim skPoint As SldWorks.SketchPoint
Dim X As Double
Dim Y As Double
Dim Z As Double
Dim L As Double
Dim H As Double
Dim B As Double
On Error GoTo main_Error
Set swModelDoc = swApp.ActiveDoc
If swModelDoc Is Nothing Then
MsgBox "Open part"
Exit Sub
If swModelDoc.GetType <> swDocPART Then
MsgBox "Open part"
Exit Sub
Dim InputDimValOnCreate As Boolean
'Suppress the dimension dialog box
InputDimValOnCreate = swApp.GetUserPreferenceToggle(swUserPreferenceToggle_e.swInputDimValOnCreate)
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
Set swPartDoc = swModelDoc
Open pathName & "JointSpace.txt" For Input As #4
Input #4, L, H, B
boolstatus = swModelDoc.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Set swSketchMgr = swPartDoc.SketchManager
swSketchMgr.AddToDB = True
swSketchMgr.DisplayWhenAdded = False
swSketchMgr.InsertSketch True
swModelDoc.ClearSelection2 True
vSkLines = swSketchMgr.CreateCornerRectangle(0, 0, 0, 5.25175614406384E-02, 4.50560499791269E-02, 0)
boolstatus = swModelDoc.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 0.02152359075436, 4.47690687690688E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = swModelDoc.AddDimension2(2.12366095443018E-02, 5.73962420116266E-02, 0)
'Set myDimension = swModelDoc.Parameter("D1@Sketch1")
'myDimension.SystemValue = L
swModelDoc.Parameter("D1@Sketch1").SystemValue = L
boolstatus = swModelDoc.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 0.120655737704918, 6.81967213114754E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = swModelDoc.AddDimension2(0.162622950819672, 7.40983606557377E-02, 0)
boolstatus = swModelDoc.Extension.SelectByID2("D1@Sketch1@swModelDoc11.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
'Set myDimension = swModelDoc.Parameter("D2@Sketch1")
'myDimension.SystemValue = H
swModelDoc.Parameter("D2@Sketch1").SystemValue = H
swModelDoc.ShowNamedView2 "*Trimetric", 8
Set myFeature = swModelDoc.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, B, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
swModelDoc.SelectionManager.EnableContourSelection = False
'myDimension.SystemValue = 0.015
Close #4
'D1@Boss-Extrude1
Open pathName & "Particle_1_Coordinates.txt" For Input As #1
swSketchMgr.Insert3DSketch True
Do While Not EOF(1)
Input #1, X, Y, Z
Set skPoint = swSketchMgr.CreatePoint(X, Y, Z)
Loop
Close #1
Call AddSpheres(X, Y, Z)
Open pathName & "Particle_2_Coordinates.txt" For Input As #2
Do While Not EOF(2)
Input #2, X, Y, Z
Loop
Close #2
Call AddSpheres2(X, Y, Z)
Open pathName & "Particle_3_Coordinates.txt" For Input As #3
Do While Not EOF(3)
Input #3, X, Y, Z
Loop
Close #3
Call AddSpheres3(X, Y, Z)
swModelDoc.ShowNamedView2 "*Isometric", 7
swModelDoc.ViewZoomtofit2
main_Exit:
On Error Resume Next
If Not swSketchMgr Is Nothing Then
swSketchMgr.AddToDB = False
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, InputDimValOnCreate
Exit Sub
main_Error:
MsgBox "Error: " & Err.Number & " (" & Err.Description & ")"
GoTo main_Exit
Private Sub AddSpheres(X As Double, Y As Double, Z As Double)
Dim swFeat As SldWorks.Feature
Dim swFeatMgr As SldWorks.FeatureManager
Dim skSegment As SldWorks.SketchSegment
Dim bStatus As Boolean
Dim D As Double
If Not swSketchMgr.ActiveSketch Is Nothing Then
Open pathName & "Particle_1_Size.txt" For Input As #4
Input #4, D
Set swFeatMgr = swModelDoc.FeatureManager
'Select "Front" plane
bStatus = swModelDoc.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
'Insert new sketch
'Create arc
Set skSegment = swSketchMgr.CreateArc(0, 0, 0, 0, D, 0, 0, -D, 0, -1)
'Add vertical line
Set skSegment = swSketchMgr.CreateLine(0, D, 0, 0, -D, 0)
'Add arc center point to current selection
bStatus = swModelDoc.Extension.SelectByID2("", "SKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
'Add "Midpoint" relation between arc center point and vertical center line
swModelDoc.SketchAddConstraints "sgATMIDDLE"
'Clear selections
'Select vertical line
bStatus = swModelDoc.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
'Add dimension
'Set swDispDim = swModelDoc.AddDimension2(-D, 0, 0)
'Exit sketch
'Add Revolve feature
bStatus = swModelDoc.Extension.SelectByID2("Sketch2", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("Line1@Sketch2", "SKETCHSEGMENT", 0, 0, 0, True, 4, Nothing, 0)
Set swFeat = swModelDoc.FeatureManager.FeatureRevolve2(True, True, False, False, False, False, 0, 0, 6.28318530718, 0, False, False, 0.01, 0.01, 0, 0, 0, False, True, True)
'Clear selections
'Get the body
bStatus = swModelDoc.Extension.SelectByID2("Revolve1", "SOLIDBODY", 0, 0, 0, True, 1, Nothing, 0)
'Move the body to the first point
Set swFeat = swFeatMgr.InsertMoveCopyBody2(X, Y, Z, 0, 0, 0, 0, 0, 0, 0, False, 1)
'Clear selections
'Get the body and 3D sketch
bStatus = swModelDoc.Extension.SelectByID2("Body-Move/Copy1", "SOLIDBODY", 0, 0, 0, True, 256, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("3DSketch1", "SKETCH", 0, 0, 0, True, 64, Nothing, 0)
'Pattern the body
Set swFeat = swFeatMgr.FeatureSketchDrivenPattern(True, False)
Close #4
Private Sub AddSpheres2(X As Double, Y As Double, Z As Double)
Dim D As Double
Open pathName & "Particle_2_Size.txt" For Input As #4
Input #4, D
'Insert new sketch
'Create arc
'Add vertical line
'Clear selections
'Add dimension
'Exit sketch
bStatus = swModelDoc.Extension.SelectByID2("Sketch3", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("Line1@Sketch3", "SKETCHSEGMENT", 0, 0, 0, True, 4, Nothing, 0)
'Clear selections
'Get the body
bStatus = swModelDoc.Extension.SelectByID2("Revolve2", "SOLIDBODY", 0, 0, 0, True, 1, Nothing, 0)
'Clear selections
bStatus = swModelDoc.Extension.SelectByID2("Body-Move/Copy2", "SOLIDBODY", 0, 0, 0, True, 256, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("3DSketch2", "SKETCH", 0, 0, 0, True, 64, Nothing, 0)
'Pattern the body
Close #4
Private Sub AddSpheres3(X As Double, Y As Double, Z As Double)
Dim D As Double
Open pathName & "Particle_3_Size.txt" For Input As #4
Input #4, D
'Insert new sketch
'Create arc
'Add vertical line
'Clear selections
'Add dimension
'Exit sketch
bStatus = swModelDoc.Extension.SelectByID2("Sketch4", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("Line1@Sketch4", "SKETCHSEGMENT", 0, 0, 0, True, 4, Nothing, 0)
'Clear selections
'Get the body
bStatus = swModelDoc.Extension.SelectByID2("Revolve3", "SOLIDBODY", 0, 0, 0, True, 1, Nothing, 0)
'Clear selections
bStatus = swModelDoc.Extension.SelectByID2("Body-Move/Copy3", "SOLIDBODY", 0, 0, 0, True, 256, Nothing, 0)
bStatus = swModelDoc.Extension.SelectByID2("3DSketch3", "SKETCH", 0, 0, 0, True, 64, Nothing, 0)
'Pattern the body
Close #4
