Hi Guys,
How you all doing? It's been a while since my last query. :-)
Btw, I am not that familiar with sheet metal feature and I have tried using the welded corner on this part and on some instance I am able to apply it but, on the other open relief I can't seem to make it work.
Am I missing something. I do appreciate any heads-up on this matter.
Am I misunderstanding something here? it works for me.
How do you apply weld bead?
You're done.
You have to set weld bead visibility to be able to have a visual effect.
Your file with applied weld bead is attached.
